4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#726818 03/05/2011 1:39 AM
During the last cold spell my speedo (55.1 3100) started making horrible noises and the needle jumped around, sometimes claiming I was going 80 when I knew I was under 40. Seems to be less present with somewhat warmer weather. Speedo cable is near new, BTW.
Can I lube this thing somehow--or some other fix--or is this thing due for replacement/rebuild?
Kermit #726826 03/05/2011 2:13 AM
Plastic or metal speedo cable?
Bigtonka #726830 03/05/2011 2:28 AM
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=687043&Searchpage=1&Main=99769&Words=%22Speedo+lube%22&Search=true#Post687043
Sounds like it could use a little light lube.
Bigtonka #726831 03/05/2011 2:28 AM
Metal.
Kermit #726834 03/05/2011 2:40 AM
with a new cable, the most likely problem is a gummy speedo head, I think you're stuck with opening it up and cleaning the spinning bits right at the input .... see here
Kermit #727075 03/05/2011 11:12 PM
Did you change the housing, or just the cable inside? Quite often, the problem is a worn or damaged outer housing, causing the cable to bind and chatter. Grease or powdered graphite will help a little, but both the cable and the outer sheath should be changed as a set.
Best way to isolate the problem is to disconnect the cable at the speedometer and drive the truck. If you still have the noise, it's in the cable - if not then it's in the speedometer.
Huck #727365 03/06/2011 11:11 PM
Yup. Changed the whole tamale, went metal housing. Actually, some noise was present both connected and disconnected. I guess I pull the speedo and have a look. After 56 years, I guess it's due.
Thanks, one and all.
