| | | Forums66 Topics128,259 Posts1,058,291 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72665 02/02/2007 3:27 AM | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | O.K., income tax return time and now I can get started on the old 57 3200. I have a trans AND rear axle question. I have a 235 engine and I thought a 3 speed floor shift trans. I thought I read in another post here that if it has a floor shifter it is a 4 speed. Mine has a hurst shifter someone put in it before I got it and it is a 3 speed shifter. Is this 3 speed transmission stock ? I wanted to restore the truck all original if possible. Also, the rear axle appears to be shot. In netural it will roll backwards, but locks up rolling forward. I am trying to figure out first of all which rear end it is.American Truck VIN decoder lists 2 for this truck, 3.90 or 4.11 OD. I assume if it is a 4 speed it is the 4.11 gears and 3.90 if a 3 speed. Any help on if the trans is a stock 3 speed and if so a 3.90 rear end? Links to the trans opening & shifter below. [img] http://i128.photobucket.com/albums/p199/johnmarkp/57shifter002.jpg[/img] IMG] http://i128.photobucket.com/albums/p199/johnmarkp/57shifter001.jpg[/IMG] 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
#72666 02/02/2007 3:31 AM | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Oh @#%@!!& I didn't mean to attach the photo, just the link. SORRY! 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
#72667 02/02/2007 3:31 AM | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | From what I understand, the three speeds were standard in 1/2 tons. Four speeds were options for the trucks until you got into the big bolts.
I remember my dad explaining to me as a kid that the only reason he bought is 1966 Nova SS was because it was the only way to get a 4 speed standard.
Yeah, it wasn't the 283 or anything .... | | |
#72668 02/02/2007 10:52 AM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Lots of help identifying Chevy truck 57' engines, transmissions and rear ends on this page from this fellow stovebolter's site. It tells you where to look for the letters and numbers and what they mean. http://www.chevytrucks.org/mikesgarage/1957.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#72669 02/02/2007 7:57 PM | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | That's an original tranny with a darned inconvenient, short Hurst floor shifter that someone without the sense to rebuild their column shifter plugged in there. 1951 3800 Be the change you want to see. -hotshoe
#72670 02/02/2007 10:16 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hotshoe is right. It,s a 3 speed trans. Pull the cover off the rear end & take a look inside. You may have a broken spider gear. You can roll them out without pulling the pumpkin or tearing it down. The ratio is on the edge of the ring gear. It is in number of teeth. Divide the numbers to get the ratio. 4.11 would be 10-41. 3.90 will be similar. Or you can count the teeth & divide. Follow a repair manual or shop manual to pull the spider gears. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#72671 02/03/2007 1:54 AM | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Thanks guys for the info & advice. Maybe it won't be as big a project (or as expensive) as I thought. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
#72672 02/03/2007 3:12 PM | Joined: Aug 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 37 | Alan's57- My guess is that that tranny is from a '58-64 car. The reason is because the '56 and 2 '57s that I had used the 3-speed with the longer tail shaft which did not have a mount on it. The cars went to a mount on the tranny when they switched from front motor mounts and bell housing mounts to side motor mounts and a tranny mount. If you look toward the rear of the tranny (which is a 3-speed)you will see a tranny mount. Just my 2 cents.
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
#72673 02/03/2007 5:46 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Packrat - the standard truck 3spd was the same as the car trans, and both had the mounting ears ... the optional HD 3spd may not have had the ears, as it was meant for the trucks ... the HD 3spd also had a variant with the propeller shaft e-brake  ... I've got a number of the standerd 3spds from TF trucks, and they're as pictured Bill | | |
#72674 02/03/2007 5:47 PM | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | Alan, My understanding is that the standard rear end for task force trucks was a 3:90 for all transmissions except the overdrive which used a 4:11 ratio. It is quite evident as Packrat mentioned that it has a later transmission. The later trucks also used this short tailhousing from around 61 through 67 but it did not use a rear mount. This transmission has the the same gears as the long tail housing version. It is probably like most 50 year old vehicles and has been changed,updated, and modified as necessary to keep it on the road. Fred
#72675 02/03/2007 9:03 PM | Joined: Aug 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 37 | Red58-It is possible that some of these may have been changed through the years but I had a '55,56' and 2 57s and they all had the long tail shaft with no mounting ears. My buddies '56 GMC also has the long tail shaft with no mounting ears. On the 56, I put in a stock overdrive which is longer and didn't have to modify the driveshaft. I still doubt that the trannys '57 and earlier would have the mounting ears since chev didn't go to a tranny mount crossmember til '58. I did have a 3 speed from a '71 Nova that had the long tail shaft and mount. It was also syncro all 3 gears and not only 2nd and 3rd like the older ones. 50 year old vehicles are likely to have anything in them now. Just recently saw a picture of a '57 Chev hardtop with a Ford flat head v-8. What a way to drop the value.
#72676 02/03/2007 10:22 PM | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | O.K. then, whatever this trans is, can an original stock floor shifter be mounted back on it? It dosen't look like it ever had a column shift unless the column has been changed too.I have the trans/floor access cover(which was not bolted in because the Hurst shifter does not line up with the hole) and would like to have the truck look original.What are the chances of finding an original shifter & linkage and can it be mounted to this transmission? 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
#72677 02/03/2007 11:51 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. The 3 speed never used a floor shifter on the Task Force body trucks. The column shifter used on these trucks actually bolted to the top of the column, not integral with it like on later trucks.
Bill Burmeister | | |
#72678 02/04/2007 2:29 AM | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Well, it looks like I need to find a used column with the shifter assembly still attached. That will go nice with the used rear axle assembly I just discovered I will need.I can fix about anything when it comes to body work,but mechanics I have to ask a lot of questions.Not knowing a lot about rear axles, even I knew it was a bad sign when I took the housing plate off and nothing came out but chunks of rust. The ring & pinion gears have teeth broken,but the other gears looked ok. There is about 1/2 inch of rusty crud in the bottom of the housing so I think it is probably a waist of money to buy new ring & pinion gears. Next stop, SWAP MEET. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
#72679 02/04/2007 5:01 AM | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | Alan, If your differential is full of rust and chunks, the axles and axle bearings are probably toast also. Check the ads on this site, there are lots of complete rear end assemblies for sale. Also post a wanted ad for the complete shifter assy from the column to the trans with the shift rods. There are lots of folks with this stuff. Fred
#72680 02/04/2007 5:12 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't know if it's still on there, but there was a rear from a '57 or so 1/2 ton on E-Bay a couple of days ago. Also, you don't need the entire column, just the shifter mechanism (lever,shaft,control box,shift rods) from a '57-'59 truck. Don't get one from a '55/'56, the rods are different. They have a bell crank on the 1rst/reverse rod.
#72681 02/04/2007 5:28 PM | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | That is what I like about this Stovebolt web site. If I run into something I don't know about, everyone is right here with answers or to offer advise. There is a car show/swap meet next weekend here where I live in Lakeland Florida. I am going to check there first for parts and if I come up empty will post here for them. Thanks again. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
