| | | Forums66 Topics128,163 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 32 | I "acquired" a 1955 2-ton the other day, which of course doesn't run. It does turn over, and the previous owner said it had "wiring problems". First order of business is determining if it is 6 or 12 volt. I'm leaning toward 12 volt because the battery is 12 volt - but not taking any chances. Any help in determining is appreciated. Thanks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | howdy Doc, welcome to the garage ... you need to tell us if it's a first or 2nd series 55, that's right where the dividing line is 6 to 12 volt
Bill | | | | | Joined: Mar 2011 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 32 | It's the second series I believe - more "square bodied", not big rounded fenders. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Are you referring to a 2-ton GMC or Chevrolet truck?
Most likely you have a 1955 second-series Chevrolet truck and it is most likely 12v.
If the generator or starter have a Delco-Remy tag on them, red is 12v and black is 6v.
| | | | | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | Take a close up look at the headlight lenses. The operating voltage is embosed right on the glass lense..... | | | | | Joined: Mar 2011 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 32 | It's a 12 volt - thanks everyone. | | |
