4 members (dunfire, John Dlugos, Gdads51, Greg_H), 69 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
what kind of trans should i put in my 64 chevy i want to be able to blow the doors off of them little tunners an any FORD'S that pull up beside me but i also want to be able to pull a trailer with my chevelle on it she has a 1 ton 4 speed with a granny in it now
LEWIS
You're not into street racing are you?
Z
Z Offline
a built 700r4
well steppenwood not really but i love to leave them them sorry little cars behind me at a stop light hey zenish were can i get a 700r4 to build
LEWIS
....and sorry they are.
i cant stand the sound of them little cars but im sure there are folks that dont like my straight pipes
LEWIS
No transmission change alone will allow your one ton to beat even a mildly tuned sedan. Pretend your truck is a truck and race the Chevelle.
The granny low you have in there now is good for towing.
Paint & Body Shop moderator
427 with a 2 speed auto.
I think you need a 572 with a 4L80. No, wait a minute, that's what I need!
well baldy i have a 1/2 ton with a 283 an it is pretty fast an will do a mean burnout an old sub i would love to have a 572 but i have priced em lol
LEWIS
Burn outs just mean you aren't hooking up, and whatever transmission you choose won't change that, either. The rice burners will just disappear in a cloud of smoke; yours. Most people only use low gear (on a truck fourspeed) for starting a heavy load or if they just want to idle slowly along while loading hay bales,etc. You will find you have better quarter mile times if you start in second. Time your truck at a local drag strip; I think you will find that it is a lot slower than you think. Compare your timing slip with the advertised quarter mile speed of any modern vehicle to see how it stacks up.
baldy my truck hooks up an takes off like a bat out of hell an it well only do a burnout if i hold d brake an if any off yall r round Louisburg an want to see how slow it is im 4 miles out on 56 east
LEWIS
I start mine in 2nd. Shift into 4th at about 25. Hitting 50-55 I bend rods. That's fine by me. I get more people looking when they have to pass me and I don't have to spend so much time on maintaining the performance.
Used to have an SS Chevelle 350 with a turbo 350 (i think ... whatever was stock automatic). Person before me thought performance meant an oversized Holley that was overjetted. Didn't add much the the speed of what was already a pretty fast car, but it sure did make it fun when the secondaries got stock.
For a good burnout with that, I'd just do the old neutral drop. Problem being I was 20 and had no money for tires.
If you wanted to improve the performance of your truck trannie, couldn't you simply re-gear the rearend and not worry as much about the gear ratio's? I'm not the expert there. My four speed is 7.23:1 in first so I'm not sure if a rear end gear change would do much in that situation.
If it ain't broke, take it apart and figure out why!
39 Chevy in the Gallery
Photobucket Album
Z
Z Offline
id get one from a 1987-90 camaro.
i want a 4 speed but i think a auto would give it the right auto would give me the best of both pulling an a good take off for raceing
LEWIS
