7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl), 112 guests, and 3 robots.
Topics128,049
Posts1,055,665
#72639 02/01/2007 10:22 PM
I have gotten some info in the general truck forum but thought I would post here for more ideas. I am going to put a 350 T.B.I. engine in my 1964 C-10 and was wondering what the easiest way to connect all of the engine harness into my truck harness. Someone mentioned an aftermarket stand alone harness and controller but I don't know where to look for it. If anyone has anymore info or ideas on spliceing the harness out of my donor vehicle into my truck harness please help. Thanks.
#72640 02/01/2007 11:40 PM
Riding in the Passing Lane
Painless Performance products has a harness for that. I,ve never done it but I believe a guy could take the harness out of the donor car or get a circuit & make one up. You will need all the sensors that go with it.
1972 Chevy c10 Cheyenne Super
#72641 02/03/2007 5:38 AM
H Online: Content
Installing "all the sensors" is a pretty tough project. I retrofitted a Crossfire dual TBI 305 into a late-70's pickup once, and installed all the factory sensors, including the vehicle speed sensor behind the speedometer, in-tank fuel pump, etc. It turned into a massive project. There are aftermarket kits that give most of the factory system functions without doing a full rewire, but if you're going to that much effort, the port-injection engine would be a better choice. TBI, while more sophisticated than carburetion, is still a pretty primitive system.
#72642 02/03/2007 6:20 AM
While port injection may produce more hp than a carb or TBI ( though not always true )it can have more problems. TBI gets better mileage than a carb usually and has few things go wrong. TPI is better suited to cars than trucks though many have done them. Mainly they are looking for speed. However it is your choice. Check out the website www.goingfaster.com/spo/praisetbi.html Its quite lengthy and I've read it all. Very well thought out and someone really knows their stuff in my opinion. He compares TBI, TPI and carbs while discussing the L03 engine, the 305. Same applies to the L05/350. I have a TBI 350. Sounds like someone who has been at mechanincing for quite a long time. Just some of my suggestions to your question. I wish you success on which ever choice you make. H.
