| | | Forums66 Topics128,164 Posts1,056,965 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | those are the lines for a double acting fuel pump with the assist for vacuum wipers, someone replaced the pump with the regular one
Bill | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Thanks Bill. I suspected it was for some type of accessory but I didn't know what. I'll do some checking to see if there's any chance of finding one of those fuel pumps. I've never heard of it before so I suspect they might be rare animals.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | see FP37D here - useful if you have vacuum wipers Bill | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Classic Parts has them for $95. I need to make sure my vacuum wipers work ok before I spend that money. If not I'll buy electric wipers instead. Thanks for the help.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'd suggest the electric wipers are the way to go, much more dependable long term
Bill | | | | | Joined: Feb 2011 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 29 | Hello Jeff, I've been looking for dual action fuel pump lines. If you don't goe withthe dual action I'm interested in purchasing them. email [email protected] | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You can bend your own lines. Were they ever pre bent, from the factory so to speak? Or were they always custom made when the dual action pump was put on?
Grigg | | | | | Joined: Feb 2011 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 29 | If installed at the factory or purchased at the dealer they would have been pre-bent.
If anyone has rusted or no good for use I could use them as a pattern. pattern. | | |
