Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (Otto Skorzeny, DHedrick, TexasFarmTruck, Joe H, Sedgewick, Charles in CA, crenwelge), 153 guests, and 4 robots.
Topics128,282
Posts1,058,496
Members48,490
X
X Offline
Does anyone have a vent handle stud, the stud the actual vent handle goes on to ?
X
X Offline
I guess it would help to know what it goes on...lol
65 chevy c10
Try your local wrecking yards like Pick & Pull or Pick A Part. You will be able to get the stud and waffel washers too.
62 Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
One of mine broke off, too. I haven't seen an old truck in a salvage yard for a long time. ohwell
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Go to http://www.customclassictrucks.com/techarticles/1101cct_chevrolet_c10_door_secrets/index.html , an article on vent window repairs on a '67 C10 . I know yours isn't a '67 but it should be similar and might be of some help to you - good luck !
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
I have several, if you still need one.
X
X Offline
Yes, I'm stil looking ...I sent you a PM let me know on a price...Thanks
I had the same thing happen to me, I just removed the Vent portion by drilling out the rivets that connect the little swivel hinge to the vent assembly frame, replaced with a new one and replace rivets. you will have to bend the swivel hinge a little.
truely the easiest way is to replace the whole thing, but mine were just rebuilt and I had the replacement vent window as a spare.
