| | | Forums66 Topics128,191 Posts1,057,362 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | does anyone have one that i could buy? i need it by this weekend for the 2 ton and am willing to pay for the overnight cost. leaky brakies no goody...-DVZ | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | i meant "inch". i don't know how the "v" got in there -DVZ | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy dvzdeathtrap, The Filling Station lists p/n RW-457 utility REAR - 1 1/2" diameter $15.00, hope that helps | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | If one of the Carquest stores still has books, they are still in the books. Their computer only goes back to 1962. I recently ordered one from the Carquest here in Fredericksburg and had it the next morning. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | napa might have them in stock. if not its likely they can have them the day after you order them. if the wheel cylinder is beyond repair a kit wont help you for the weekend. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | As said before NAPA should be able to get them within a day or so. NAPA Part# UP195 RockAuto has them about half the price but I don't know if they can ship them over night. RockAuto uses Raybestos Part# WK195 or Dorman Part# 19381. Good Luck
SimS | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | once again, thanks for all the help guys. i will call around with the part #'s and let you know what pans out. -DVZ | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | got it taken care of. thanks for all the help guys -DVZ | | |
