4 members (NJC, Otto Skorzeny, Steveoreno, 1955 1 Series), 92 guests, and 4 robots.
Topics128,192
Posts1,057,234
Members48,465
Hey guys new here i have a 1958 chevy fleetside with a straight six 235 id like to be able to cruise when im done... is there any combination of tranny and rearend ratio i need to use to get descent hwy spped plus descent gas mileage... id ideally like to swap the old three speed on the columb for a aoutmatic or 5 speed manual tranny... can this be done.. and what about a 2brl or 4brl carb swap vs the old single barl...
The stock rear will be fine if you swap to an overdrive transmission. The easiest swap would be to use the factory 3 speed with the Borg-Warner overdrive, it's a direct bolt in. You can usually find them for around $150.
The next option, if you want to stay manual, would be to use a T5 from an S10, which would get you the overdrive gear. That swap has been covered numerous times. try doing a search for "T5 swap" to get the specific information.
Going automatic will require an aftermarket adapter, either from Langdons or Buffalo, as the 235 will not directly bolt up to the modern overdrive automatics.
Bill Burmeister
thks for the info bill!
I don't know if you live or drive much in a large city but i have a t-5 in my 54/235, but if you do you may want to seriously consider an 700r4 automatic. i like the t-5 and on the highway i get 20-23 mpg but when i go to Indianapolis to see my son an auto would be nice.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
V
V Offline
I have a 1950 Chev. "DeLux SportCoupe" which came from the factory with the 235 cu.in. and "PowerGlide" transmission. Upgraded it with a 1961 235, higher lift cam, fenton headers,and overhauled the "PowerGlide" (had it since 1951 and 67XXX miles ago)kept the orginal intake and carburator. The old girl gets away from the stop signs and down the highway with no problems at all. Took me a long time to get the new water pump from "Patricks"
I kinda "Ball Parked" the horsepower at around 130HP, compared to the orginal 100 HP. (It`s fast enough for me and the wife. (Had her since 1951 also.)
Good for you, VerCoMo.
2017 Buick Encore
See more pix
Do you still have the original engine? I'm looking for a correct-number 1950 Bel Air 235 to use on a restoration project.
V
V Offline
Yes;
I pulled the engine last summer, it had been overhauled about 25 yrs ago. I would guess the engine has less than 10XXX miles on the ovrhaul. Didn`t smoke, no unusual noise.
It`s been sitting outside between the silos since last summer.
I had to use the front engine mount for the new engine, so, you would have to replace the front covers. It`s also missing the intake/exhaust and carburator.
I told another "interested party" that it would have to be gone by the 1st of May or the slavage yard would own it. $100.00
