| | | Forums66 Topics128,117 Posts1,056,298 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | I just bought a replacement gas pedal, but it doesn't have a hinge. The existing one in the truck looks like it came from a hardware store and is not original. Does anyone know if this part is available? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Grego 55 - It is available, but the correct pedal doesn't have a "hinge". The pedal actually has a small "pocket" at the botom of the back of the pedal that slips over the raised piece of metal rivited to the toe board of the truck. You slip it into the "pocket" and push the top of the pedal onto the ball at the end of the accelerator rod which comes through the toe board from the bell crank on the the side of the engine. It "rocks" back and forth as the pedal is moved up or down when pressed down to accelerate the truck.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | Thanks, mine's gone. Maybe its something I can fabricate. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Thanks, mine's gone. Maybe its something I can fabricate. This is the gas pedal tab on the floor. The picture of the tab doesn't show it very well. The tab is spot welded to the floor. You say your tab is gone?
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | It's actually riveted to the upper toe board on a 37, two rivets
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I have seen the larger trucks with a different pedal then the 1/2 tons. | | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | Tab is gone. Thanks for the picture, it helps alot. | | |
