0 members (), 106 guests, and 2 robots.
Topics128,115
Posts1,056,292
Members48,439
#72561 01/31/2007 1:33 AM
I found a military waterproof distributor for a GMC and would like to use it in my 235,will it fit as I found someone who could convert it to electronic and it would look neat in my truck. Jeff
#72562 01/31/2007 1:52 AM
I do beleive that the distributors are completely interchangable from the GMC to the Chevy on those engines.
Bill Burmeister
#72563 01/31/2007 3:09 AM
the waterproof military dizzy was 24 volts... guess that doesn't matter if you are having it redone
#72564 01/31/2007 3:11 AM
Would check to make sure the drive gear on the distributor matches the cam. Pre55-235 engines ran forged cams with forged distributor gear, while the 56 and new engines run a cast cam and should use the cast gear. The distributors swap, but running the wrong distributor gear can play havoc with your cam.
The forged gears tend to be smoother on the flat sides while a cast gear has a rougher side surface but it's best to varify with parts numbers. I learned this the hard way. Hope this helps you avoid my mistake.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#72565 01/31/2007 6:29 AM
Junior Member
Junior Member
I believe that the early 235 engines are the ones with the cast cam( Milk Can Lifters). All the high pressure 235's and 261's used the forged cams.All GMC motors, 228-302, used a Cast cam. So the distributor would have to be changed out if it is a high pressure 235 or 261.
BAN LOW PERFORMANCE DRIVERS...
NOT HIGH PERFORMANCE CARS !!
