| | | Forums66 Topics128,115 Posts1,056,294 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72561 01/31/2007 1:33 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I found a military waterproof distributor for a GMC and would like to use it in my 235,will it fit as I found someone who could convert it to electronic and it would look neat in my truck. Jeff | | |
#72562 01/31/2007 1:52 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I do beleive that the distributors are completely interchangable from the GMC to the Chevy on those engines.
Bill Burmeister | | |
#72563 01/31/2007 3:09 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | the waterproof military dizzy was 24 volts... guess that doesn't matter if you are having it redone | | |
#72564 01/31/2007 3:11 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Would check to make sure the drive gear on the distributor matches the cam. Pre55-235 engines ran forged cams with forged distributor gear, while the 56 and new engines run a cast cam and should use the cast gear. The distributors swap, but running the wrong distributor gear can play havoc with your cam.
The forged gears tend to be smoother on the flat sides while a cast gear has a rougher side surface but it's best to varify with parts numbers. I learned this the hard way. Hope this helps you avoid my mistake. | | |
#72565 01/31/2007 6:29 AM | Joined: Mar 2005 Posts: 37 Junior Member | | Junior Member Joined: Mar 2005 Posts: 37 | I believe that the early 235 engines are the ones with the cast cam( Milk Can Lifters). All the high pressure 235's and 261's used the forged cams.All GMC motors, 228-302, used a Cast cam. So the distributor would have to be changed out if it is a high pressure 235 or 261.
BAN LOW PERFORMANCE DRIVERS... NOT HIGH PERFORMANCE CARS !!
