0 members (),
44
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Howdy! I was wanting to buy new shocks for my 57 half ton GMC soon and i was wanting to know if anybody here had any suggestions on what type to get. What brand and/or size should i get? I dont have the originals anymore so i dont really have much to match up with, and the truck is down to the bare chasis so i cant really get an accurate measurement on the travel distance. The suspension is stock hieght. Thanks and Gig'em | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If you get a name brand you should be fine ,and you can get them from a FLAPS ,just get stock ones they will be the right ht.that are made for you're truck.
Pete | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Are all four the same size? Cody | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I think you should find the correct shocks listed at a good parts house, whether they're still available or not ... the front and back are different because of different loading front and back ... not sure GMC is the same, but the Chevy numbers are: rear, Monroe "Limited Edition" LE10018 [pair] or Gabriel 82060 [each] ... front, Monroe 3100 or Gabriel 82047
Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
