| | | Forums66 Topics128,126 Posts1,056,351 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 10 New Guy | | New Guy Joined: Nov 2010 Posts: 10 | Does anyone know who makes the brackets or if they ever made any for the chevy 230? I need them if they make them.
1965 Chevy Straight Six Lover
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | GM did, but they are often hard to find. Try EBay.I've seen them there. You will also need a double groove crank pulley too as they used separate belts to operate the pumps/alternator.
Drew
| | | | | Joined: Nov 2010 Posts: 10 New Guy | | New Guy Joined: Nov 2010 Posts: 10 | Will the double crank pully off a 235 or 250 fit the 230?
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | check your crank pulley , you may already have a spare one there. ron | | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | Car or truck the pump brackets will fit 194,230,250 & 292. | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Man I have seen people ask this question a hundred times, never really saw a good answer to the problem. I thought about doing power steering and air conditioning and finally just said to heck with it and put a 350 in my gmc.....Kieth
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
