3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
I have '64 GMC longbed stepside, and I've always had repair manuals for my vehicles.
Which is the one to get? From what I've gathered, there is a 1962 shop manual out there, and a 1964 supplement. Are both needed?
I've also seen a CD with electronic versions of the manuals for 1962-1963-1964 GMC Pickup and Truck Shop Manual CD. I like this option, because although I like a physical manual, I also like to print off the pages I need to take to the garage. Anyone have this, and is it worth it? This has manuals that don't really pertain to me, so is kind of overkill. I'd like to just find a PDF of the manual for my truck, but it doesn't seem to be out there.
Are these my two options, or is there something else out there I'm missing that I should get?
There is one place that you have not looked, and it is there - only there - that you shall find the master.
mweishaa, what you need is a 63 manual with the 64 supplement.
Also, you should get the factory assembly manual.
If you want to stay stock and add options, there is an options manual as well.
I personally don't have the CD although your point is valid.
Check out the http://www.6066gmcguy.org/Manual.htm
There is a picture of what you need. Plus a lot of good info.
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Whoa, I stand corrected. I didn't catch that you had a GMC. My advise works for a Chevy.
Sorry.
Better stick with Jon S's advise.
Jon S, thanks! I've been all over that site so I'm not sure how I missed that.
It outlines it nicely, but no real opinion on how good they are. It does say that the assembly manual wouldn't be of much use to a GMC owner. That right there is very valuable feedback.
I may look into those, and do some checking to see if the CD version contains these. Anyone have the CDs and care to comment on their quality/completeness? Feel free to PM me.
Well, I ordered this, so we'll see how it turns out:
http://www.faxonautoliterature.com/...ckup-and-Truck-Repair-Manual-P22413.aspx
Well, got the CD today with the 4 manuals on it in PDF format.
1962_GMC_MAINTENANCE_MANUAL_MODELS_1000-5000.pdf
1963_GMC_MAINTENANCE_MANUAL_SUPPLEMENT_P-PB1000-2500_MIDELS.pdf
1963_GMC_TRUCKS_SUPPLEMENT_TO_MAINTENANCE_MANUAL_MODELS_1000_THRU_5000.pdf
1964_GMC_MAINTENANCE_MANUAL_SUPPLEMENT_MODELS_1000-5000.pdf
Seems to be pretty good quality, I am sure they'll be put to good use. The only thing is that it contains all engines and has several supplements. If I find the time, I may try to put together just the pages for my truck into one PDF so I don't have to do quite as much searching across the manuals.
For $30 + shipping, I think it was well worth it.
