3 members (cmayna, tclederman, 1 invisible),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10 New Guy | | New Guy Joined: Mar 2010 Posts: 10 | I restoring 54 chevy 1 ton/3800,can any one tell me if the ft. inner and outer fenders are the same as the 1/2 & 3/4 ton truck.This truck did not have a bed on it when I got it. It has a 137'' wheel base, and I think it had a (9')bed on it.Does any one know what the total lenght of the bed sides are. Thanks for any help. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Yes, I have a 49 chev. 1-ton and I used inner and outer fenders off of a 51 GMC. They fit and bolted right up.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Dec 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 40 | I have 54 chev 1 ton with a replaced front fender. My original paint fender seems to be almost twice as thick of metal. Ive always wondwered your same question. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I put the entire nose (fenders, inner fenders, hood, grille, latch pan, lower splash pan etc etc ) from a '53 1/2 on to my '48 1 ton. Everything bolts up. The only difference is the radiator core supports are different between the 1/2 ton and 1 ton. Use your 1 ton radiator core support. They bolt to the cross member differently. | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | And also be advised that as long as you stay with '54 parts, you shouldn't have any issue. Can someone confirm that the '54 and '55 1st fenders are a little different (from the '53 and earlier Advance Design) to accommodate the different grille?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Yep, '54 and '55 1st front fenders are differant from the earlier Advance Design. The '54 and '55 1st have indentations where the parking/signal lights mount and also because the grills are differant. Other than that I believe they are the same.
Bruce | | |
