| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72520 01/30/2007 8:34 PM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | Second of some questions -
The oil that is in this thing looks to have been there for at least 10 years. Black and very thick. So it needs to go.
In fact I am thinking of dropping the pan off and cleaning it, fill up with oil, run, and drop the pan again before one final fill up.
This is a C-30 with a 292 that doesn't match the year of the truck...engine is a '70's model. How hard with this be and am I headed in the right direction? Anything I need to look out for?
Dave 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
#72521 01/30/2007 10:46 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s a good idea to pull the pan in a situation like that but it,s a pretty tough job on that model. You have to take the engine mounts loose & raise the engine way up. You certainly wouldn,t have to pull it a second time. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#72522 01/31/2007 12:02 AM | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | Had a '60 Chevy 235 and I would change the oil and within 100 miles the oil was black. Stuck a stick in the engine and found a sea of muck in the pan. Something I tried and it worked great. Get the engine hot. Drain the oil and fill the crankcase to the full mark on the dipstick with a 50/50 mix of fuel oil and transmission fluid. Run for 2-3 minutes and drain. Only let the engine idle! Don't drive it! On the 2nd flush, I had the valve cover off and poured the mixture over the rockers while the engine was running. After about 3-4 flushes the stuff started staying clean when I drained the pan. Gave it an extra shot for good measure. Problem solved.
It never costs more to ask and it never costs more to think big.
#72523 01/31/2007 1:06 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I had an uncle who did this on his Chevrolets back in the late 40's and 50's. Only he used kerosene. He would drain the engine, fill it with kerosene, run it for about ten minutes and drain the pan. He would do that twice and he would swear that he maintained the cleanest engine in town. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#72524 02/01/2007 8:51 AM | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | My dad talks about doing the kerosene wash during the 50's, and of course it cleans the oil out pretty good. Working in a garage in the 80's we had a fellow bring in a Pontiac where for whatever reason gas had drained into the oilpan. Luckily we drained that out before the roof blew off. In any event, in both cases, afterwards the engines were both so clean that the oily gunk which had been plugging up all the old seals had washed away, and both engines used way too much oil. Just a thought, an old clean engine might draw a bit more oil. Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
#72525 02/01/2007 2:22 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | A problem you may run into is what is called "false seals". As gaskets and seals go bad due to age and abuse they would normally start leaking/seeping. The grunge you want to remove has "packed" the bad seals so when you remove the grunge, your false seals goes with it. All of a sudden you've got a clean engine leaking all over the place. Gaskets and seals can be replaced much easier than a hard to find engine, It's par for the course and a good reason to spend time in our shops breathing fire into these old iron horses.
#72526 02/01/2007 3:25 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just my opinion...but a flush on an engine that has been setting up for years, is not going to do much to rid the ole girl of that heavy sludge that cakes up the lower sump. If you've got the skills, pull the pan, use a putty knife (because that's what it's going to take) and dig out the grung. If the rockers are caked, it wouldn't hurt to carefully remove them, and off the vehicle, give them a good cleaning and flush. I wouldn't break a lot of stuff loose on the top of the head. You don't need that cascading down into the pan after you add the new oil. Just bolt the rockers back on, check her valve adjustment, replace the pan, stick in a new filter and oil'er up.
While you've got the pan off, it's a good time to check out the overall condition of the guts. I've found that a really gunked up engine may still give you some good service, but if it's cruddy on top and down below, you're probably at, or getting close to a rebuild. The thick crud is moisture, remnants of fuel from blow-by, and solid particles that are a result of the combustion process. The engine probably wasn't running that good when she was taken out of service. It's also a good time to knock out any dents or dings and square up the gasket surface.
A heavily gunked engine, to me, is indicative of one that is reaching the end of it's service life before a rebuild. A clean top, clean rods and a little hard sludge in the lower pan aren't going to raise that much concern. Popping a rod cap or two can give you even a little more info. If she's running, and the oil pressure is stable, you might be able to stretch a few more miles out of the engine.
Beltfed, hit it on the button about the old seals and gaskets. Even a 10 year old rear main that has been sitting idle, has the potential to cause you much grief. As the weakest component in an engine, you will probably wind up having problems with it even if everything else is clean and looks good. You may get lucky for a while!!!
If you plan on hitting the highway and running your little engine hard, you'd be better served, to do your overhaul before you bust something and wind up with a pile of useless junk. | | |
#72527 02/01/2007 4:30 PM | Joined: Dec 2006 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 65 | One more thing to watch with flushing old engines, chunks of crud can break loose and clog the pick up on the oil pump. I think Fla 54 make a very good point. Just my 2 cents.
Sean
doing what you love is happiness loving what you do is freedom
#72528 02/02/2007 1:16 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I think it's a good idea to pull it once to give it a good cleaning. Pulling it again isn't necessary because the drain plug is at the lowest part of the pan. Anything that is flushed by the fresh oil should exit the pan when you pull the plug.
