0 members (), 148 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
#72507 01/30/2007 3:42 PM
I
Apprentice
Apprentice
I Offline
I'm a newby, but I'm looking for some advice. I have a 53 3100 with recently rebuilt 235. Want to put an automatic behind it, mainly to be a simple cruiser and some highway travel. Need the automatic because I'm a right leg above knee amputee. Which trany would you recommend and with what rear end ratio? :confused:
#72509 01/30/2007 8:52 PM
I agree with toomany on the trans part, but if your running tall tires then I would recommend a taller 3's rear like maby 3:42 or 3:55.
The low 3's would put you really low on the final ratio and cause the trans to kick in and out of O.D. all the time.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#72510 01/30/2007 9:26 PM
I'd personally go with the 700R4, they're much more common and have a better 1rst gear for in town driving. I do agree with wilbur on the final gear. I have an S10 wiht a 700r4 in it and 4.10 gears, the gearing doesn't hurt it at all in o/d at highway speed.
Bill Burmeister
#72511 01/30/2007 10:35 PM
Riding in the Passing Lane
It,s pretty tough to put one behind the 235. You need a special adapter. How about changing to a v-8 or 63 up 6 cyl.
1972 Chevy c10 Cheyenne Super
#72512 01/31/2007 3:59 AM
I have 3.08 gears in the rear of two of my vehicles.
My GMC Suburban with a 270 with a SM420 runs down the highway at speed just fine and without seeming to strain the motor. That's with no OD.
The other one has overdrive and runs 70 at 3000 direct, and 2000 when in OD. Its a 350 V-8 so its not a good comparison to the 235, but the OD is programmed so it just stays there unless I want it to shift.
I would not be afraid of running 3.08 gears if you don't plan to tow a trailer or carry heavy loads. If you'll be running it loaded very heavy you'll be locking it in direct, or wishing you had lower gears.
#72513 01/31/2007 9:44 AM
I
Apprentice
Apprentice
I Offline
I really appreciate all the ideas. Thanks for the advice. I wanna stick with the 235 for now, mainly because its paid for, and if something goes wrong with it, I can always update or rebuild then. I was leaning to the 700R4 and I like the idea of rearend in the high 3's. Thanks again! smile
