1 members (Otto Skorzeny),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | Looking for wire chart showing wire gauge for different applications. Any good places to buy wire? | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | You might try the local NAPA or Carquest store. That is where I get most of my wire and wiring supplies. They might have charts showing the different gauges of wire and applications. Jim | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Do a search for "American Wire Gauge"(awg) and you will get the charts you need. Here's an example; http://www.rbeelectronics.com/wtable.htmThe IIRC third chart down "WIRE GAUGE SELECTION TABLE" will tell you what wire size you need for max amps, and distance. Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | Thanks for the help, that is a handy chart
Larry | | | | | Joined: May 2010 Posts: 20 New Guy | | New Guy Joined: May 2010 Posts: 20 | Any good places to buy wire? Electrical Terminal Service is one of the suppliers we use at work.
Ted My ride but looking for a Deco Bolt for the wife.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Just a suggestion. Once you decide what gauge wire and color to use, you need to think about types of insulatiion. They ain't all the same. I use a cross-link polyethylene called 'SXL'. It withstands temps up to 257 degs F and is resistance to moisture and most solvents/oils found around cars. I think...this is the type of wire used in most commercial wiring kits. I get mine from "Del City", but I believe you can find locally at a trailer or trailer supply store.
