3 members (Ponchogl, carbking, 1 invisible), 66 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#723903 02/24/2011 6:49 AM
Looking for wire chart showing wire gauge for different applications. Any good places to buy wire?
Camsore #723917 02/24/2011 8:07 AM
J M Offline
You might try the local NAPA or Carquest store. That is where I get most of my wire and wiring supplies. They might have charts showing the different gauges of wire and applications.
Jim
J M #723994 02/24/2011 5:07 PM
Do a search for "American Wire Gauge"(awg) and you will get the charts you need. Here's an example;
http://www.rbeelectronics.com/wtable.htm
The IIRC third chart down "WIRE GAUGE SELECTION TABLE" will tell you what wire size you need for max amps, and distance.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #724212 02/25/2011 4:35 AM
Thanks for the help, that is a handy chart
Larry
Camsore #725108 02/28/2011 12:33 AM
Electrical Terminal Service is one of the suppliers we use at work.
Ted
My ride but looking for a Deco Bolt for the wife.
Toolbox #725143 02/28/2011 2:42 AM
Just a suggestion. Once you decide what gauge wire and color to use, you need to think about types of insulatiion. They ain't all the same. I use a cross-link polyethylene called 'SXL'. It withstands temps up to 257 degs F and is resistance to moisture and most solvents/oils found around cars. I think...this is the type of wire used in most commercial wiring kits. I get mine from "Del City", but I believe you can find locally at a trailer or trailer supply store.
