Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (woodrow2002, cmayna, dt235sd, Thom75, 1 invisible), 111 guests, and 3 robots.
Topics128,290
Posts1,058,557
Members48,491
I have a '60 and am planning on installing disc brakes, which cuts out the existing hydraulic clutch cylinder. Short of spending 500.00 for the aftermarket combo master cylinders, has anyone 'engineered' an easy way to keep the hydralic clutch?
Thanks guys!
Phil
How about using a clutch m/c from a later model truck? All GM manual trans full size trucks since '88 have hydraulic clutches. You could adapt that to operate your clutch.
Bill Burmeister
Junior Member
Junior Member
i have a firewall mounted booster/mc on my streetrod. i used the clutch master cylinder from a mid 80's fiero. it is small and mounts next to the brake booster
Jeg's has several single and dual master cylinders with a variety of bores and mounting styles to choose from for less than $100. Just make a new bracket and mount them up.
Paint & Body Shop moderator
