0 members (),
171
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | Trying to save a buck I bought a cheap aftermarket volt gauge at a swapmeet, popped it apart and have the guts mounted to the background (?) of what WAS the amp gauge . BUT , I already have a new repro fuel gauge and speedometer - I need to repaint the background part to make it match the fuel gauge . What color - or where can I get it - its sort of a olive drab with a little brown tint to it . Also , I just noticed (after driving it like this for 4-5 years now) that the Speedometer background doesn't match the fuel gauge either - it's Grey ! | | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | I can't do the decal route because the only decal that I'v seen anyone has is for a amp meter , I switched the guts out and now its a volt meter . I can do the white lettering with dry transfer lettering from a hobby shop - just cant find a match for the background color . | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Pretty interesting Will the volt meter your using have the same needle sweep?
Will the needle match?
Will it fit in the original housing? Or are you going to have to modify it?
I've thought about doing the same thing.
If your successful post some pics and instructions.
I would just probably still use the amp decal and just note the needle position or have someone scan the decal and change the lettering. But this project is down the road for me
I don't know a color match for Gage face, maybe someone will chime in on that Good luck and keep us posted on your project | | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | Yea the sweep of the needle is the same as is the shape of the needle . My fuel gauge is orange but I can change that to white pretty easily . I drilled out the mini rivits on the original amp gauge to remove the background piece . The round background on the aftermarket volt gauge had mini screws and I just had to enlongate the original backer to let it mount together . I Still have to adjust the holes on back of the '49 gauge "pan" so the new studs will line up ok . Can't do much more until I get the color right though . | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | Bears38,I have all of the gauges,and the speedometer,they are used but still in good shape.If you are interested,I will get some pictures for you. The speedometer is missing the needle. My email is [email protected],Thanks. | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | | | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | I went to a hobbyshop and found a color match for the background color - Khaki Drab . the brand I got is Tamiya and its acrylic , I even brushed it on (didn't feel like messing with my old airbrush) Smoothed out nicely . The hobbyshop also had some white numbers in their Dry Transfer section , will pick them up next time I get there . | | |
