3 members (Shaffer's1950, UtahYork, Rich'sToys), 99 guests, and 0 robots.
Topics128,094
Posts1,056,064
Members48,433
#724730 02/26/2011 7:09 PM
Wondering if it is possible to install any sun visor on a 37 and still be able to keep the swing out windshield? Has anybody ever done this successfully where it wont fall off or vibrate at highway speeds and tear off the driprails? Thanks.
Ex Hall Monitor
Ex Hall Monitor
If you're referring to the Fulton visor it didn't/doesn't mount to the drip rail. Check the hyperlinks in my sig to see one on a '38.
Nice 38 coupe, however it has a 2 piece stationary windshield that supports the center of the visor. That seems to me to be the biggest issue here to get figured out. Any suggestions?
Ex Hall Monitor
Ex Hall Monitor
Fulton made a model for non split windshields. I don't know the model number. It's a good reason to start hitting swap meets. grin To answer your question about why it doesn't blow off as you drive down the road, there's a 2-3" gap all across the back that lets the air flow through. Here's some more info about the Fulton.
Thanks for the info. I didn't know they made one for a nonsplit. Thanks again.
