1 members (Southerntruck), 134 guests, and 0 robots.
Topics128,192
Posts1,057,353
Members48,469
picked up another 57 chevy 1/2ton this one has front Dampers, is this normal from dealer?? Ive never seen this before. there heavyyyy!
http://img64.imageshack.us/i/img7548w.jpg
http://img844.imageshack.us/i/img7546medium.jpg/
never seen anything similar and nothing listed in the assembly manual RPO's so it's definitely not "normal" .... is the truck a NAPCO? how exactly was it mounted on the truck? did the truck have shocks?
its a 1/2 chevy 2WD truck, when i was taking it off it seems it was there from the start..didnt seem aftermarket when i was unbolting the frozen rusted bolts.. Ive never seen this before also..maybe a one of i kind frame??
I also tried to hunt down frame #'s, there is none anywhere(front & under cab)very weird !!!
yes there is front shocks, the damper mounts to front spindle rear/behind drum plate..
the 4 holes on damper/spindle are perfect this must/has to be original equipment. just so weird.........
I also posted this question on another forum,someone replied saying they where mounted on GMC models.
still with all my years thinkering with 55-59's ive never seen this before.
hmmm, steering damper, to control shimmy on rough roads ... wouldn't be considered part of the frame if bolted on and with it's own tag/part number .... I think not all plants stamped the vin on the frame rail until late 57 and later and there's never any number besides that one
well you should hang onto them and try to track the full story for sure, but I'd say they're a fairly uncommon special order accessory
That was an option on the GMC trucks. The theory behind it is that the I beam axle resonates at a certain freequency. The dampers resonated at the same freequency but opposite of the axle canceling out all road vibration. I had a pair on my first 59 gmc. I didn't notice any substantial difference with or without them.
yep im hangen on this pair 4 sure!! might be worth more then gold blush
Shop manual page describing them. That was certainly a new one on me. There's no mention of them in the Chevrolet manuals, nor a listing in the spec sheets. I suppose a dealer could have installed them. Personally, it looks to me like they would make the problem worse by adding too much unsprung weight to the axle.
Bill Burmeister
I would say it also adds more weight to the frontend , these things are heavy!
that shop manual picture is spot-on..thats it!
