7 members (Otto Skorzeny, UtahYork, Ponchogl, Lonnie, Bicounty, BC59, JW51),
160
Mod | | | Forums66 Topics128,089 Posts1,056,129 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | planning to drop a 350 with a th350 tranny in my 51 GMC longbed. Anyone see any issues to think about?
1951 GMC 3 window 100 1951 GMC 5 window 100
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There are plenty, the first of which is it's a sin to put Chevy engines in GMCs.
But besides that you'll have issues with your steering box, among other things. This is a common swap and there has been plenty already posted about it. | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | I'll turn to reading the posts. Thanks for your response
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | "There are plenty, the first of which is it's a sin to put Chevy engines in GMCs."
Cletis, isn't that exactly what the factory does? When I went looking for a 350 Chevy engine core for my roadster project, one place that had some cores available was the local Pontiac-GMC truck dealer.
All you street rodders out there: The best source of 350 Chevy engine cores I found when I was looking for one was the Chevy and GMC dealers. Surprisingly, their price ($100) was a fraction of what private sellers were asking on Craigslist and in the local newspapar. I got one from a dealer who let me pull the pans to find a 4-bolt unit with a standard bore and a perfect looking crankshaft within factory specs. All he asked was that I put the pans back on the ones I rejected.
Ray
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Cletis, isn't that exactly what the factory does? That is what they do now but contrary to popular belief, GMCs weren't "the same as Chevies" in the '50s. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have not seen a TH350 installed without cutting the bellhousing cross-member out. I would not do this to my truck.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | why not, cut it out and fab one to put a little further back wtbd?...
yar what do you mean call the dealer for a 350? they just happen to have a bunch sitting around?
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That cross-member is tied into the front cab mount on the outside of the frame...
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Cletis, to each their own. There just aren't a lot of original GMC engines out there. If my AD GMC 3/4 ton had an original motor, I'd have kept it that way. But it didn't. Saying it's a sin is addressing roughly half the AD-owners out there. ...Just sayin'.
Yar, that's a very good tip, thank you. I've been looking for a 350 engine core and didn't want to pay up to $1350, which I've actually been quoted from one salvage yard!
Turnintotruckin, I put a 350 engine in my AD truck, because at the time, my weaker-than-a-wet-noodle 235 CHEVY engine went bad and the 292 Stovebolt I had my eye on was sold the day before I came up with the money. Yes, the steering box is in the way. But I worked around it by spacing the box 1 inch outboard (it'll stretch), and turning a pair of block-hugger headers upside down. But the preferred method is to replace the steering box altogether.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hey Turnintotrucking......it's your truck....do what you like ! There are some aftermarket suppliers out there for modified trans members & motor mounts. Do a search here on the steering issues - they have been discussed a lot. | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | thank you all for your replys. this website is priceless because of people like you. I will keep all posted. the only reason I was going with a 350/350 is I have one in my Nova that was coming out anyway. You see, I have 2 51' GMC 100's. One is a complete 3 window truck that I will restore with the original 216 that's in it. The other will be a resto mod 5 window that had no drive train in it. The frame is already modified and I actually have the transmission x member to install. As soon as I figure out how to post pics, I will have plenty of stuff to show you.
Barry
| | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | It is your truck do what you WANT to do. I am doing about the same with a sbc350 and t-400 trans. Yes there some steering box issues and drivetrain that you will have to overcome. There is a group of purest that think any mods are a sin but I wanted to enjoy driving my truck not stuck in the garage fiddeling around with it to keep it running imho | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Silverado_9c3, Chevy and GMC truck dealers install "rebuilt" engines for their customers. The old engine that comes out is called a "core". The dealer must either return the "core" or pay a "core charge", usually $100. They are glad to sell you the "core" for the "core charge". It costs them nothing and you now have something to rebuild.
Many people believe that a "core" that has been through 1000's of heating and cooling cycles is completely dimensionally stabilized and superior to a "green" casting.
Ray
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | mustache man, doing an engine/trans swap is not a lifetime commitment. I was a 20 year old college kid when I got my '36 Chevy pickup in 1965. I swapped in a Chevy V8, B & M Hydrostick and 58 chevy pickup rear end and drove it like that for about 50,000 trouble free miles. Then in the early 70s I decided to restore it to all original condition and that was a total success. The 35 year old restoration still looks very presentable and we enjoy the '36 almost as much as our street roadster. Bottom line, enjoy it-it's yours!
Ray
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | yar I know what a core is but a 350 has not been in a production model chevrolet for years now, I would venture to say all that are out there are out of factory warranty
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | They still sell 350 Goodwrench engines and some dealers charge a core charge on them. The one I bought from didn't. | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Take a look at the crate 350s. I put one into my 58,runs great. I think this is cheaper than rebuilding a core engine and you have a new motor and 100k warranty. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | hanksrags, from where I sit it's a huge leap of faith to use an engine assembled by someone else. Was he hung over that day? Did he use a $14.95 timing set or a Cloyes "True Roller" timing set? Did he use cheesy cast pistons or good hypereutetic pistons? Did he check all the clearances? Did he degree the cam in? Did he stagger the ring gaps properly? Was it honed with a torque plate? Is the rotating assembly balanced? Etc, etc, etc.
Ray
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | wow paranoid much yar? hahaha
| | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Same problem with every new car. The motor has a 100k/3year warranty. I appreciate your comments, and would be concerned if this was a race motor. Just a stock driver. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Silverado_9c3, I guess you could say, "not entirely confident in others", "paranoid" seems like overstatement to me. How well to do any job, and in fact whether to do it at all or to farm it out, is an entirely personal decision.
I discovered as a teenager, about 50 years ago, that my standards are higer than most other people's standards. Even as a kid, I saw 2 options; lower my standards or do important tasks myself.
Asembling an engine is an example. Using a quality timing set that will stay tight means it won't wear out quickly retarding the camshaft which reduces low RPM power and requires constant ignition timing adjustment. To me, it's a real pain to replace a timing set with the engine in the car and I'll gladly spend some extra money on a quality Cloyes "True roller" set to avoid that miserable job.
Honing with a torque plate means the rings will have a truly round bore to seat against and be able to seal much more effectively yielding less oil consumption and better compression. I have a very high mileage rebuild on the engine in my '71 Dodge van that I bought new and it still uses almost no oil.
Balancing the rotating assembly means on the rare occasion when I feel like revving it up and feeling the secondaries open while merging with freeway traffic it will have the smoothness of an electric motor.
Using brass freeze plugs instead of cheap steel ones means I won't ever have to replace a freeze plug in that engine. My restored '36 Chevy pickup still has the brass freeze plugs I put in almost 40 years ago.
Etc.
Is it worth the effort? To me it's well worth it on many levels. To others it may be a complete waste of time and money. Both opinions are perfectly OK in my book.
Ray
