1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 32 New Guy | | New Guy Joined: Nov 2010 Posts: 32 | My question is, is it possible to remove a manual transmission from a 1965 chevy truck without pulling the motor, since the cross member is rivited in and cant be removed??? | | | | | Joined: Nov 2010 Posts: 32 New Guy | | New Guy Joined: Nov 2010 Posts: 32 | I guess what I mean is ..can I do it with the bell housing on?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes. The engine is supported at the bellhousing, the transmission doesn't support any of the weight.
Bill Burmeister | | | | | Joined: Nov 2010 Posts: 32 New Guy | | New Guy Joined: Nov 2010 Posts: 32 | I was worried about the clearance issue, is there enough room to slide it out with the bell housing on the tranny. It sure looks like it wont have enough room to clear the floor pan and the cross member. Thanks | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | You're right. Bellhousing won't slide out the backside. Tranny will. Why do you need to remove them both. The bell holds up the rear of the motor. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I was worried about the clearance issue, is there enough room to slide it out with the bell housing on the tranny. It sure looks like it wont have enough room to clear the floor pan and the cross member. Thanks If its a 3 speed it will come right out. If it is a 4 speed you will need to remove the shift lever & the cab floor panel. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2010 Posts: 32 New Guy | | New Guy Joined: Nov 2010 Posts: 32 | Im doing a transmission swap taking a 4 speed out of a donor truck and putting it behind a new engine in the truck im restoring that had a 3 speed in it. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The swap should be easy enough. You will need the floor panel from the donor truck, they are different between 3 speed and 4 speed.
