| | | Forums66 Topics128,163 Posts1,056,962 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 53 | I am trying to find information on my truck Vin number. Everything I have found talks about completely different numbers then what I have. I am thinking this is maybe because my truck was made in Canada. The Vin plate says "General Motors of Canada Limited". Any help would be greatly appreciated.
Ken
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Kennyjr, welcome, it would be very helpful if you would post the number you have found, your serial number should be something like 41423----, which breaks down as follows 4 - year, in this case 1954 1423 - 3/4 ton, 5800lbs. g.v.w., 125" wheelbase ---- - the remainder of the number is your trucks regular production number, hope that helps. | | | | | Joined: Sep 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 53 | Thanks for the reply. The number is 41433014XX, what does the code 1433 mean? Thanks again for the help.
Ken | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Kennyjr, your serial number indicates that you actually have a one ton truck. 41433 breaks down as follows 4 - year 1954 1433 chassis with cab, 8,800 lbs. g.v.w., 137" wheelbase, hope that helps | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Kennyjr, the book lists the g.v.w. for the maximum tire equipment, I had a quick look, and could find no reference to a 6900 lb. g.v.w. in my 54 maintenance manual. With all the maximum equipment your truck has a maximum g.v.w. capacity of 8800 lbs., hope that clarifies. | | | | | Joined: Sep 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 53 | OK thanks again. I will see if there is maybe something the Ministry can do to help me out.
Ken | | |
