| | | Forums66 Topics128,032 Posts1,055,438 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 10 New Guy | | New Guy Joined: Feb 2011 Posts: 10 | I'm little new to this and have a 52 3100 that has all original running gear and electronics, can anyone tell me if theese trucks ran a positive or negative ground?? | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | My 49 is a negative ground. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | welcome to the garage 52bolter, if you have a Chev it is neg
Bill | | | | | Joined: Feb 2011 Posts: 10 New Guy | | New Guy Joined: Feb 2011 Posts: 10 | Thanks for your help, I had it hooked up that way and it ran and lites worked, but when I took my Generator to be rebuilt as it was not charging, the guy said it should be a neg grd. Has anyone heard of this?? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for your help, I had it hooked up that way and it ran and lites worked, but when I took my Generator to be rebuilt as it was not charging, the guy said it should be a neg grd. Has anyone heard of this?? Is that a mistype? As posted above, your truck was originally negative ground. Here's an ignorant side-observation: it has been a long time since I had to deal with a bad generator; but, years ago when I had a charging problem I'd take both the voltage regulator and the generator to the electrical shop. I thought this would allow a professional to confirm where the problem was and allow for adjustment of the voltage regulator, if necessary. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Chevy electrical systems were negative ground, while GMC's of the same year had a positive ground system. The generator can be polarized to work either way. Original-equipment regulators had different part numbers for positive or negative ground polarity, while most replacement units are wired to work with either polarity. I second the motion to let the rebuilder adjust the generator and regulator as a matched set. Back in the 1950's, my father had contracts with several trucking companies to rebuild and calibrate generator/regulator pairs, which were swapped out on a time or mileage cycle for preventive maintenance. This practice virtually eliminated charging system-related road breakdowns. Jerry
