| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | I have been spraying it with WD40 and trying to turn it with Vise Grips but won't give. Not sure if stuck open, is there any way to tell? | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Check out this thread: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=701198&page=. I used Thunderbolt on mine.I think something like that will work better than WD 40. I sprayed a little everyday for several days, tapped it with a hammer, put the pliers on it. Eventually I got it free. The posts should tell you what position it is stuck in.
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I don't know if this will help, but it is the manifold off my 1954 235 engine. You can see the open heat riser, and the weight position. http://share.shutterfly.com/action/welcome?sid=8Ibs2LFo3bsq8 A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jan 2011 Posts: 13 New Guy | | New Guy Joined: Jan 2011 Posts: 13 | I have yet to work on any of these old "stove-bolts" that did not have the "heat rizer" rusted in the open position.
Just takes a little patience alot of penatrating oil and a small "ball-pene hammer".
After squirting the oil around the shaft, gently tap on the ends of the horizontal shaft to break the rust loose. ( in a few years it will stick open again)Remember that you are working on a steel shaft which has lost it`s temper over the years and cast iron which tends to be brittle.
If you live in an enviroment where the temps are not really cold (Below 20 degrees), just forget about having a heat rizer. Leave it in the open position. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Camsore, all those things ever do is stick. I solved that problem on my '36 Chevy pickup by making a stainless steel shaft and staniless steel bushings for the exhaust manifold. That was over 25 years ago and it has proven to be a permanent fix.
All that hammering, twisting and penetrating oil simply doesn't fix the problem permanently, and it makes a real mess while not working. I know because I tried before finally biting the bullet and making the stainless steel parts.
I'm told by an automotive engineer that unless you live in Ethiopia, an engine warms up much more quickly with a functional heat riser. That's why the factories all used them.
Ray
| | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | Got it free. I used PB Blaster | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | How much play do you have in it if you take and try and move it up and down? I took mine apart and put a new shaft in it. There was a small bushing in the hole that the shaft rides in. Just a small circle of thin metal. Don't watch you don't loose it if you take it apart. By the way, if you take it apart you have to grind away the welds on the flap. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
