6 members (Hotrod Lincoln, 2-Ton, Wayne67vert, Pete1946, Otto Skorzeny, 1 invisible), 110 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
Junior Member
Junior Member
I have a '58 Chevrolet that I am putting a 283 with a T350 transmission in. The frame is all original. Could someone send me photos of what my engine mounts should look like and what I have to do there? And could someone send photos of what the tranny mount sshould look like? This is my first restoration. I just got my frame back from powdercoating. Thanks
My email is [email protected]
Here's a pic of the OEM motor mounts
I think the transmission mounts are on the sides of the bellhousing. But here\'s an after market mount.
To use that egine/tranny combo, you're going to have to use some sort of aftermarket mounting system. For the engine, you'll need to use the type that uses the side mounts, like the aftermarket crossmember in Seons post. There are also side mounts that bolt to the frame that do not have the crossmember, available from Speedway and JCW. For the trans, you'll need a tranny mount crossmember, similar to the engin crossmembe, only with a transmission mounting pad. The original rear sidemounts won't work with the later trans, and it needs support at the rear.
I'd suggest the you look into the bolt in style mounts as to keep damage to the powdercoat to a minimum. Check with Speedway, Jegs, or Summit. All three carry universal mounts just for this type of conversion.
Bill Burmeister
