| | | Forums66 Topics128,099 Posts1,056,501 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | I don't have good luck with the search function on this site so forgive me if this as been talked about already. would a 454ci Big Block motor fit into an advance design 1/2 ton? I am bored this evening and just wondering if i could fit such a large motor in my truck. The truck will have a Helix Suspension coil over mustang II with power brakes and steering. Has anyone done it? even better pix would be great.
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | Anyone have experience with this?
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Some. But not on an AD truck. I swapped in a 427 in place of a 327 in my Corvette. I know enough to know that the same mounts for a small block are used for the big block, and the bellhousing mounts the same. The big block is heftier though. Unless you use an automatic in your truck and move it forward, you'd have pretty significant firewall clearance issues. And you'll definitely have to do something else about your steering.
You could probably do headers if you extend them out into the wheel well, over the frame rails. And I would look for something a little better than a Mustang II front end. Simply because Mustang IIs never had BBC engines in them. The big block is going to weigh around 150 pounds more than a small block, so don't use small block springs.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | Sounds like more trouble than its worth
