0 members (), 120 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
My plans for my '53 3100 is to get it drivable for the next season or two and then tear down for a rebuild/restore. There is no rust through in the floor but plenty of surface rust. I'm looking for opinions based on your experiences as to what I should use to seal the floor with. I plan to put down a pad and rubber mat.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Z
Z Offline
I would use a rust convertor then encapsulator. Then paint. You are tearing it down in a season anyways. I wouldn;t put too much effort in it. If it is going to be garage kept and not taken in the rain then you could just leave as is for now.
52 Chevy 1/2 ton - work in progress
65 Mustang coupe - work not in progress smile
67 Mustang GT convertibile
67 Camaro RS/SS
We are now even with fords and chevys. smile
Now i need a mopar. Hahahahahahahahaha
If you can get the pans like you want them now and primed you will be one step closer to finished. Some will put it back like it was made the first time. The rest of us will do the best we can. I cleaned, sandblasted, used phosphoric acid and followed that with POR's Marine Clean then POR-15. I then dusted the last coat with primer and primed when all was dry. If you aren't doing a Fred Flintstone out of the floor it will keep for a year or two. Clean it keep it dry and do it once when you are ready.
Thanks for the responses. Since I'm not stripping the entire cab I can't sandblast so I was thinking about trying to take off as much surface rust as possible and then put a coat of POR15 down to semi-seal it. It will be garage kept.
Allan
1951 GMC 1/2-ton
That'll work. Mine were so bad that wasn't an option. If you haven't used the POR-15 before follow the directions and cautions. Especially the one about getting it on your skin. Your 53 looks great by the way.
Moderated by  ndkid275, Phak1
