10 members (TexasJim50, Jay R, TUTS 59, Hotrod Lincoln, Forty9, cmayna, Lostbuthaulinass, Woogeroo, Peggy M, 1 invisible),
89
Mod | | | Forums66 Topics128,134 Posts1,056,411 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72313 01/27/2007 9:52 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I know there has been a lot of talk about bellhousing patterns but can somebody tell me if the commercial 1.5 ton standard bellhousing is interchangable with the military version trucks? Thanks, Tom | | |
#72314 01/28/2007 11:15 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | If you are referring to the cckw, I would guess they are interchangeable. the 1.5 ton bellhousing is interchangeable with a 1/2 ton bellhousing from the same year. As for the coe bellhousing... couldn't even guess. I know the deco trucks all had the 3 tapped holes for the clutch and brake pedals to mount to. I guess interchangebility would depend on weather or not the pedals attached to the bellhousing. The coe may have used a different configuration due to engine location. | | |
