2 members (Brian Moore, panel fan), 166 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#722968 02/21/2011 4:24 AM
I restoring 54 chevy 1 ton/3800,can any one tell me if the ft. inner and outer fenders are the same as the 1/2 & 3/4 ton truck.This truck did not have a bed on it when I got it. It has a 137'' wheel base, and I think it had a (9')bed on it.Does any one know what the total lenght of the bed sides are. Thanks for any help.
Yes, I have a 49 chev. 1-ton and I used inner and outer fenders off of a 51 GMC. They fit and bolted right up.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
I have 54 chev 1 ton with a replaced front fender. My original paint fender seems to be almost twice as thick of metal. Ive always wondwered your same question.
I put the entire nose (fenders, inner fenders, hood, grille, latch pan, lower splash pan etc etc ) from a '53 1/2 on to my '48 1 ton.
Everything bolts up. The only difference is the radiator core supports are different between the 1/2 ton and 1 ton. Use your 1 ton radiator core support. They bolt to the cross member differently.
24601
And also be advised that as long as you stay with '54 parts, you shouldn't have any issue. Can someone confirm that the '54 and '55 1st fenders are a little different (from the '53 and earlier Advance Design) to accommodate the different grille?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Yep, '54 and '55 1st front fenders are differant from the earlier Advance Design. The '54 and '55 1st have indentations where the parking/signal lights mount and also because the grills are differant. Other than that I believe they are the same.
Bruce
My Trucks
Stuff I Collect
Moderated by  Dusty53
