1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72293 01/27/2007 3:22 AM | Joined: Oct 2006 Posts: 26 Apprentice | | Apprentice Joined: Oct 2006 Posts: 26 | does anyone know if you can put a big block in a 52 3100. i know i would have to change motor mounts, what else would i have to do
westerman 52' CHEVY 3100
#72294 01/27/2007 3:42 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Sure you can do it.
What are you thinking for a transmission? The stock driveline isn't likely to survive long behind a big block, but the direction you decide to go will affect some of the other changes you'll need to make.
The stock steering column isn't going to work because of proximity to the exhaust system. Its a problem on a small block, and a big block makes it a bigger problem.
Most the big block AD trucks I've seen used an IFS click or Mustang II suspension at least in part because of the steering issue.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#72295 01/27/2007 3:51 AM | Joined: Oct 2006 Posts: 26 Apprentice | | Apprentice Joined: Oct 2006 Posts: 26 | the 454 comes with a turbo 400. I have a comaro front half (steering box in front of the A aems)and a ford 8.8 rearend.
#72296 01/27/2007 8:53 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Have you already installed the Camaro clip?
If so you'll need to trial fit the motor/transmission to see where it will fit and then build mounts and crossmember. Make sure you have exhaust and distributor on the motor to make sure you have room for them.
It can be done, I've seen similar ones at car shows.
#72297 01/27/2007 9:44 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Westerman: Around here when we speak of big blocks we are usually referring to a 270/302 GMC.  | | |
