2 members (Otto Skorzeny, MickeyP), 132 guests, and 2 robots.
Topics128,088
Posts1,056,408
Members48,443
#722935 02/21/2011 2:53 AM
My Classic Parts wiring harness has wiring included for an alternator with internal regulator. Including a jumper wire from alternator BAT terminal to the alternator's internal voltage regulator, and a wire from the voltage regulator through the main connector to the ignition switch IGN1 terminal.
THE ISSUE: My alternator was rebuilt with a self-energizing voltage regulator. No wires are to be connected to it and a rubber plug was included to plug the hole over the two terminals. Literally just one wire from the alternator BAT terminal to the battery.
THE QUESTION: Can I just exclude the wires to the voltage regulator included in the harness? The ignition switch doesn't need this wire from the alternator, correct?
3B Offline
Hy Pats58, yes you can omit the wires you asked about, hope that helps.
Thank you, I was not looking forward to opening up the alternator again to replace the voltage regulator!
