8 members (1955 1 Series, klhansen, John Dlugos, Bill Hanlon, Gray_Ghost, Otto Skorzeny, 2 invisible),
219
Mod | | | Forums66 Topics128,101 Posts1,056,179 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | My Classic Parts wiring harness has wiring included for an alternator with internal regulator. Including a jumper wire from alternator BAT terminal to the alternator's internal voltage regulator, and a wire from the voltage regulator through the main connector to the ignition switch IGN1 terminal. THE ISSUE: My alternator was rebuilt with a self-energizing voltage regulator. No wires are to be connected to it and a rubber plug was included to plug the hole over the two terminals. Literally just one wire from the alternator BAT terminal to the battery. THE QUESTION: Can I just exclude the wires to the voltage regulator included in the harness? The ignition switch doesn't need this wire from the alternator, correct? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Pats58, yes you can omit the wires you asked about, hope that helps. | | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | Thank you, I was not looking forward to opening up the alternator again to replace the voltage regulator! | | |
