6 members (Ridgeback, rick46ia, Otto Skorzeny, klhansen, MNSmith, 1 invisible), 109 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#72293 01/27/2007 3:22 AM
Apprentice
Apprentice
does anyone know if you can put a big block in a 52 3100. i know i would have to change motor mounts, what else would i have to do
westerman
52' CHEVY 3100
#72294 01/27/2007 3:42 AM
Sure you can do it.
What are you thinking for a transmission? The stock driveline isn't likely to survive long behind a big block, but the direction you decide to go will affect some of the other changes you'll need to make.
The stock steering column isn't going to work because of proximity to the exhaust system. Its a problem on a small block, and a big block makes it a bigger problem.
Most the big block AD trucks I've seen used an IFS click or Mustang II suspension at least in part because of the steering issue.
#72295 01/27/2007 3:51 AM
Apprentice
Apprentice
the 454 comes with a turbo 400. I have a comaro front half (steering box in front of the A aems)and a ford 8.8 rearend.
westerman
52' CHEVY 3100
#72296 01/27/2007 8:53 PM
Have you already installed the Camaro clip?
If so you'll need to trial fit the motor/transmission to see where it will fit and then build mounts and crossmember. Make sure you have exhaust and distributor on the motor to make sure you have room for them.
It can be done, I've seen similar ones at car shows.
#72297 01/27/2007 9:44 PM
Westerman: Around here when we speak of big blocks we are usually referring to a 270/302 GMC. wink
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
