0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#722885 02/21/2011 1:06 AM
I've been having carb problems with my COE for quite some time. I suspected my fuel pressure was to high so I replaced the fuel pump, still had the same issue. I finally put a guage on the fuel line and I am getting almost 8 lbs. Is 8lb going to cause me serious problems? I think it would just want to verify.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Probably going to have a problem with your carb flooding that's to much pressure.
I've been running the inexpensive Mr. Gasket adjustable pressure regulator on my dual carb 235 set at 3-1/2 psi for the past 13,000 miles. These can be found in most automotive parts stores for around $30.00, complete with the fittings to tie into your line between the fuel pump and carb. I have a pressure gauge and have found that adding a filter between the regulator and the carb drops your pressure an additional 1 psi. If you didn't want to go to the expense of adding a fuel gauge you would be safe to run between a 3 to 4-1/2 psi setting on the dial.
There is another brand that looks like the Mr. Gasket regulator but I've had issues with that brand. None with the Mr. Gasket brand. Hope this helps you get your fuel pressure under control.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
