3 members (ShopRag, TooMany2count, J Lucas), 29 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#722888 02/21/2011 1:17 AM
Can a side mount 235 be converted to front mount? If so what do I need?
I have my eye on a 58-62 235 from a 3600 truck and I want to exchange it for the 216 in my 37 1/2 ton truck.
Charlie
I think that all that needs to be done is drill two holes in the bottom edge/lip of the plate on the front of the block (the plate behind the crank/cam gears). The 47-55 truck engine's front motor mount is attached through those two holes.
Maybe someone has a picture or a link to a tech tip?
http://www.stovebolt.com/techtips/engine_swap_216.htm
use the plate on your 216 as a drilling template?
tclederman #722946 02/21/2011 3:12 AM
Most of the later model 235's I've seen have already been drilled for the single front mount. If you're running the bellhousing with the 2 side mounts it'll just be a matter of adding the single front mount.
However, you're going to have to do some scouting to find 2 of 4 of the necessary front mount components: the box and the plate that hold and sandwich the rubber insert. The insert and dust cover are available from most vendors but I could never locate a source for the 1/8" thick base box and upper 1/8" plate.
Also want to add that it is critical to grind down a stock GM front box for adequate clearance as the replacement rubber inserts aren't as thick as the originals and even though it APPEARS you'll have enough you won't when the weight of the engine is added. You WILL have engine vibrations radiating through the frame if the clearance isn't increased and you won't realize it until you have all the sheetmetal installed. I covered some suggestions in my webshots albums. A little extra time getting the front mount clearance correct before the truck is buttoned up will save you HOURS of blind, arm-bending, wrench-throwing labor.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Fla54Chevy3100 #723484 02/23/2011 12:37 AM
Dave,
Do you have any pictures of the parts I need to be looking for?
Charlie
37FamilyBowTie #723608 02/23/2011 11:52 AM
look in the teck tips under motor mounts. There is a picture of all the pieces. That's how I found what to fab up for my mount for my 235.
Larry
58 gmc 100 with 350 sbc
LarryW #723651 02/23/2011 3:51 PM
Would the set up from the original front mount 216 that I am taking out work by chance for the new 235?
Charlie
37FamilyBowTie #723750 02/23/2011 10:37 PM
Charlie,
I have a picture from the repair manual of the front mount on page 12 of my Webshots "Tips and Tricks" album. It's extremely important to insure that you have about 1/8" clearance between the top plate and the box WITH WEIGHT on the mount. I clamped the box into a vise to determine that the amount to remove from the box was 1/8".
The single mounts are identical for all the front mount 216/235's. I'd suggest you put a "wanted to buy" ad in the stovebolt classifieds.......fabricating a new mount without having the original would be a shot-in-the-dark."
Dave
Fla54Chevy3100 #723762 02/23/2011 11:09 PM
1932-54 truck used the same front mount.
My Blog
Pre '68 Dave #724665 02/26/2011 4:36 PM
New motor is on its way. Just want to make sure I have what I need for the front mount.
This is what i have from the old front mount for the 216.
What other parts are need for the new 235?
http://i543.photobucket.com/albums/gg447/Seykoras/Truck004.jpg
http://i543.photobucket.com/albums/gg447/Seykoras/Truck003.jpg
http://i543.photobucket.com/albums/gg447/Seykoras/Truck002.jpg
http://i543.photobucket.com/albums/gg447/Seykoras/Truck001.jpg
thanks for the help,
Charlie
37FamilyBowTie #725999 03/02/2011 10:19 PM
Looks like you have everything you need. Now carefully mark and drill those holes. I 'marked' the holes for mine (235 that was a side mount) by first referencing the holes on my front mount 216.
1946 Chevrolet 1/2-ton
More pix on Photobucket
Charlie,
I made the same modification on the engine I put in my truck. The advice and jigs that are in the Tech Deck are spot on. Good luck...measure twice and cut once!
Cheers,
Carlos
