| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | How much do the sides weigh approx? Both long and short sides.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Are you looking for the exact weight or are you looking to find out if you need 2 or 4 guys to move the bed around? | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I'd like to know close to exact weight. I guess they are around 150 to 180 each. I will disassemble and reassemble with the bed pulled back a foot or so, sitting on blocks on the frame. I don't like help, help usually goofs things up.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you're concerned whether you can handle one bedside by yourself, you shouldn't have any problem, but you won't remove the bedsides without cutting welds at the rear cross sill .... 2 people minimum to move the whole bed around minus wood floor
Bill | | | | | Joined: Jan 2011 Posts: 42 New Guy | | New Guy Joined: Jan 2011 Posts: 42 | but you won't remove the bedsides without cutting welds at the rear cross sill .... 2 people minimum to move the whole bed around minus wood floor
Bill yep DONT CUT THE WELDS....one of my fleetside's without wood and cross bars is light enuff for 2 to carry around like bill said above. withwood i have no clue...good luck. | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Even the step sides are welded at the back,if memory is correct. And what do you mean don't cut the welds? I will cut them and there is no reason to weld there, as it is bolted too. Right The bed has to come apart to clean it well.
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I took my bed completely apart. The short fleet bedsides probably only weighed 45-50 lbs. each is my guess. At any rate, I had no problem lifting them by myself.
Oh, and those welds at the back? Cut 'em, baby! You can always reweld them later if you want to. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | odd comment Truckolet, considering your "Factory stock is the only way to go" position on another thread  I've refurbished 2 fleet beds without disturbing those welds, the one that's been my daily driver for about 15 years and this one that I later soldif there were no reason for it to be welded there the factory wouldn't have wasted the manpower and material do do so Bill | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Factory stock, yes. But to replace that rear cross still the welds have to be cut. For concourse yeah reweld them. By factory stock I have always meant to make it as close as you can to stock. Of course when you drill spot welds etc you are not factory stock, niether is a big gapping rusty hole either. As soon as you do any fix it thing it is not factory stock. I think it is called RESTORATION. On another note, the long fleet side panels are maybe 80 lbs guessing. I personally had to take the box apart to be able to store the parts inside while they wait their turn.
