1 members (Forty9),
113
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Forgive me guys, for most likely asking a question that's been asked a gazillion times. The "search" on here for my topic doesn't help me at all. First, I need a source for purchasing valve guides for my 261 head. NAPA has straight shank but my originals had collars. Does anyone have a good source for these? Secondly, is there a recommended method for installing them? The old ones were so brittle, I fear my hammer method might not be best. Should I somehow heat the head and freeze the guides? This pops in my head as one way to go about it. I've never done this before. Any input on this is appreciated! Jerry | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Hellomrwilson, I'm not sure if different year 261s had different procedures, the following info came from a 1954 maintenance manual. The valve guides can be pressed out on an arbor press, they are pressed out from the spring side down through the combustion chamber, they use a shouldered tool to accomplish this. There are two different lengths of guide, the intake guides are longer than the exhaust guides. The guides should be pressed into the head from the spring side until the intakes are 1" above the spring seat, and the exhausts are 15/16" above the spring seat. Once installed ream the guides to .343 with a hand reamer, hope that helps. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Jerry, why not have modern bronze sleeves installed into the existing guides? That is the method used by competent machine shops in reconditioning heads. Bronze guide liners are also used in manufacturing aftermarket heads. They are in the Edelbrock heads I bought for my street roadster.
That may be more cost effective and will provide a superior finished product. The trick will be finding a person to do it competently, especially if you are in a rural area. I moved from an urban area of California to a rural area and the concept of doing things properly simply does not exist here.
Ray
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Most machine shops stopped sleeving guides about 20 years ago or so. While the procedure is effective in the short term, replacing the whole guide makes for a longer-lasting job. The guide-sleeving process was mostly used by shops that didn't have a dedicated seat/guide machine to do the guide removal/replacement process accurately. Jerry
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Thanks for the tip, Ray. The old guides are completely removed and destroyed. I'll have to install new ones like Jerry stated. My old guides appeared to have integral flanges (what I referred as collars). I have been trying to locate that type with no luck. Bobb, I'm afraid I haven't had much luck with anyone in my area concerning pressing the guides. I may have to do it myself. Jerry offered a procedure that I am willing to try. Jerry, thanks for the help. Maybe I should buy a few extra just in case? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I'm quite sure your guides with collars were not original. Chev stopped using them in 1936. The GM parts book lists "1940-62 all 6 cylinder" for your engine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Thanks Dave. I wouldn't doubt that the guides aren't original as the engine's been rebuilt before. I've accepted that my new guides are going to be the straight shank type. At least I know I can get those. I'm pumped and ready to getRdone! | | |
