7 members (Forty9, Jay R, TooMany2count, J Lucas, Gdads51, Goach2, John Dlugos), 209 guests, and 1 robot.
Topics128,094
Posts1,056,155
Members48,436
#722102 02/18/2011 2:13 PM
Just bought a 1937 pick-up. Started and ran when coming off the trailer, then died and won't restart. I got rid of a tankful of old gas, been sitting for a year. I have spark and gas flow to the carb, but it won't start and keeps backfiring in the carb. I have tried changing the timing, but that doesn't make sense because it was just running. Any suggestions?
It's pretty common for old gas to cause valves to stick in the guides. Pull the valve cover and crank the engine, and see if you've got some valves that aren't moving right. A compression test could also help spot a cylinder or two with sticky valves.
What carb are you running. Some times the float will stick from old fuel and not let any into the carb
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
Ex Hall Monitor
Ex Hall Monitor
Agree with Jerry, sounds like sticking valve(s).
Thanks guys. I'll look at the valves. I checked the carb and the float & needle are not stuck.
Well, timing is right on, valves aren't sticking, replaced points & condensor, now going to replace plugs (look nasty from too much idling)and coil (mechanic friend says spark from coil wire should be blue when held against ground, kind of orange color spark now). All electrical and timing seems to be OK but still won't fire and pops back thru carb. I'll let you know what happens with new coil and plugs.
