4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
Junior Member
Junior Member
Can someone offer advice on the best way to adjust manual drum brakes (for my 62 K20)?
I replaced most of the brake system this weekend to include master cylinder, wheel cylinders, front drum, had the rears turned, and new shoes all around.
After getting everything back together, bleeding it out and fiddling with the adjusters, it's much better, but still not quite right. It pulls a bit and I seem to be going around in circles making adjustments.
What's the trick?
I wouldn't recommend drugs, alcohol, and violence to anyone...but they've worked well for me.
On mine I had wheel on, in the air tightened till brakes dragged heavy , to nearly impossible to turn by hand and then back off 7 clicks.
Junior Member
Junior Member
Thanks, Ken. Is there any order (front to rear, left to right) to the madness?
I like the tighten-them-up first part but I would back them off until the wheels turn freely, you still may hear a little scraping sound, that's o.k. The only sequence involved is when you bleed the brakes. Start with the wheel farthest from the master cylinder first, then the next farthest, etc.
Toe in and other front end alignment issues will make a steering pull.
"It ain't a truck if you can't hose out the cab."
