8 members (Maybellene, tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible),
198
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 14 New Guy | | New Guy Joined: Apr 2010 Posts: 14 | I was wondering if anyone has used a t5 with a 26 spline input shaft? I found one locally on craigslist for a good price and was wondering if this would work or not? Any input would be great! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Seems it should work as long as you can find a clutch disc that is for a 26 spline input shaft and will be the right size for the pressure plate and flywheel to work with. The vehicle that the T-5 came out of would be first vehicle to look at.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Also, be sure you have the right bolt-up pattern on the transmission or know of a transmission adapter plate that will work.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You might have to change out the entire tail shaft housing.I think the shifter is going to be too far back.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I was wondering if anyone has used a t5 with a 26 spline input shaft? I found one locally on craigslist for a good price and was wondering if this would work or not? Any input would be great! you will need to identify the trans. the two T5's with 26 spline are the Camaro 5.0 V8 and the Ford 5.0. the 26 spline is the strongest input shaft on the T5 (good for 330 lb-ft of torque vs the anemic 14 tooth splined shafts which are rated at 220 lb-ft). If it is a Camaro unit, you can very very easily swap in an S-10 tail shaft and shift rail to move the shifter up. this will give you a T5 Hybrid that will be stronger, use a standard GM clutch disc, and handle a V8 unlike modifying the T5's with the 14 spline input shafts by cutting the bearing retainer, elongating the splines and trimming the input pilot, the 26 spline unit is already the right length, has long enough splines and the short bearing carrier. Here is some much needed reading http://www.mongosgarage.com/tech/t5/index.htmhttp://www.inliners.org/Jack/T5tech.htmlhttp://www.inliners.org/Jack/t5_page.htmlhttp://www.ttcautomotive.com/English/media/pdfs_autogen/T-5_Service_Manual.pdfhttp://www.thirdgen.org/techboard/transmissions-drivetrain/48307-t5-tranny-info-all.htmlhttp://www.jalopyjournal.com/forum/showthread.php?t=171291&highlight=s10http://www.jalopyjournal.com/forum/showthread.php?t=169265
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Scott,thanks for the additional information on the t-5 transmissions.
| | | | | Joined: Jul 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 27 | Hey scott and Tim pardon me butting in ,but I've got an anemic 14 spline t-5 and I'm trying to take the steps to get it used with a 1955 non modified 235.I've got the 169 tooth flywheel and a 10" clutch and this t-5 with 14 splines on a 7" shaft,1/2' pilot.Can you tell me where to find a 14 spline 10" clutch plate? And sir,please direct me to the reading if any that applies to this install.Appreciate your help and direction .Sid Stephenson --down near Houston | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | If you choose to use the 26 spline shaft you'll need to check out the info listed in the "Hybrid T5" Tip to relocate the speedo "drive gear" on the mainshaft. In reality I can see no use for changing out a 14 spline shaft for a 26 spline GM transmission when you can get the whole T5 "Z" V8 transmission for a couple hundred bucks. The only real problem you're going to have is with the Camaro disc/pressure plate on your flywheel if you're running it behind a 216 or a 235. Several have made the change to the "Z" box which has much better ratios all the way up to the .63 5th gear.
As for the clutch plates behind the .72 0r .86 T5's I've used the RCF4201 from NAPA and also the disc from behind a 2.8L 83-84 Firebird in my 235 truck. They are a 9-7/8" disc and I outlined the process to make the transition work the first time....in my Webshots album. Hope this helps you both.
Dave | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | T-5 14 spline clutch disc part numbers
9" disc is 4190
9 7/8" disc is 4201
11" disc is 4212
| | | | | Joined: Jul 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 27 | Tim and Dave --thanks to you both --just got back home and got this info --I'll wander on down the path and come back to you both with project report.Hope all is well,Sid Stephenson | | | | | Joined: Apr 2010 Posts: 14 New Guy | | New Guy Joined: Apr 2010 Posts: 14 | Thanks so much for all the info. I ended up finding one with the 14 spline input shaft, 3.76 1st gear and mech speedo, so im going that route instead. Im putting behind a 235, and I was going to ask for more info about clutch discs but you already answered that for me. Thanks again! | | | | | Joined: Apr 2010 Posts: 14 New Guy | | New Guy Joined: Apr 2010 Posts: 14 | I lied, I actually have 2 more questions haha. I've been looking through all of the t5 tech pages and have not been able to find much info on pressure plates. Can I just use my stock pressure plate or do I need one from a small block? Also will I need to change the slip yoke on my driveshaft in order for it to work with the t5? The truck is a 58 apache 1/2 ton with a saginaw 3 speed for what its worth. Also wondering if anyone has used this adapter http://hamiltonintakes.com/products/s10-t-5-swap-adapter ? Thanks again.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can use the original pressure plate. You will need a yoke with the fine splines. They were on practically erything from 68 up except TH400. You will have to have the drive shaft shortened. I have done several & have never used the adapter. The modifications are easy. Just make sure you grind the splines enough. Its no fun pulling it out again. Slide the clutch disc on the shaft till it stops. Mark it & measure about 3/8 to 1/2 in. Grind the grooves till it slids back that far. The results are fantastic. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Hey scott and Tim pardon me butting in ,but I've got an anemic 14 spline t-5 and I'm trying to take the steps to get it used with a 1955 non modified 235.I've got the 169 tooth flywheel and a 10" clutch and this t-5 with 14 splines on a 7" shaft,1/2' pilot.Can you tell me where to find a 14 spline 10" clutch plate? And sir,please direct me to the reading if any that applies to this install.Appreciate your help and direction .Sid Stephenson --down near Houston look up '87 and '88 Astro Van with V6 and 5-speed.
| | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | Sid I sent you a PM. I'm going to be putting a 14 spline t5 behind a 235 in the future. Rick......... | | |
