0 members (),
134
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72154 01/25/2007 1:57 AM | Joined: Sep 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 46 | I am planning on putting disc brakes on our new acquisition a 60 Chevy stepside. Rather than replace the torsion suspension am considering modifying the A arms to accept later model spindles. I have seen the kits and don't want to spend the hi bucks. Does anyone know if the later model spindles will fit on the existing upper ball joints? I know I have to modify the lower A arms for new ball joints. I want to either go with the newer 6 bolt spindles or 5x5 truck spindles. Cost is a key factor. Thanks | | |
#72155 01/25/2007 2:10 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | you can get dropped spindles for your truck for around 230 dollars that will allow you to use 80s c10 disc brake parts, | | |
