0 members (),
61
Mod | | | Forums66 Topics128,179 Posts1,057,160 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Hi guys, building a 46 suburban and am pretty sure I am going to run a smoothie type steel rim with the stock looking center caps. Which size wheels would you or are you running? I was thinking maybe 15x6 up front with 15x7 or 8's out back. They will be 5 lug by the way. What are you 41-46'ers running.
Not staying stock, so I really do not need those opinions. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I,m running 17" with 275 wide tires on all 4 corners. | | | | | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Nice looking truck! Thanks for your input. Anyone else? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't have one that early, but I do work in the tire industry and can put in some input. A big factor in what width wheel you'll need is the tire size you plan to run. With a 15 x 6, you really limit the width you can run, 215 or 225 would really be the safe limit. If you're wanting a wider tire, go with a 7" rim minimum. Other things to consider is what suspension/rear axle will be used. That will affect the backspacing and potentially width availability.
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I'm keeping it simple, I'm going to run 15 X 7 Rally wheels on mine. Probably 235/70/15 on the rear, 225/70/15 on the front maybe a little smaller on the front. I just bought a set that came with 275/60/15 on them but way too tight in the rear due to the stance and no tubs. I have a 75 Nova rear end under it. | | |
