| | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | The rear drums on the 58 2.5 ton that I'm working on would turn a little, but the inside lip wouldn't come past the shoes - a common problem. Of course the starwheels were stuck and even if they weren't stuck the chances of seized cylinders preventing inward movement were high, as the truck's been sitting for 30 yrs. I used a small hydraulic jack to get the drums off: place the base of the jack horizontally against the side of the leaf springs; rotate jack until you get it to pump up, as most such jacks won't work horizontal exc. in certain positions; place top of jack against inside of wheel spokes if you have Daytons or against a solid slab of steel bolted to the drum and projecting past it; put pressure to the jack, first on one side of the drum, then the other (back & forth), and the drum popped easily past the edge of the shoes. No prybars needed, and no sweat or cursing - I was amazed at how easy this method worked. Hope this helps someone out there.
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Thanks for the tip...sounds like you're on your way! Don't forget we like pictures  Mike B  | | |
