5 members (Ponchogl, MickeyP, Bill Marlow, 48jim1ton, 1 invisible), 119 guests, and 0 robots.
Topics128,049
Posts1,055,552
Members48,425
#72129 02/17/2007 4:20 PM
1 Offline
I was in the salvage yard a few weeks ago and I found a 1973 GMC 1/2 ton with a 12 bolt rear. Has any one tried to use these axles in an 67-72 12 bolt rear? I'm guessing they won't work but I'm not sure, and I haven't run across a set of 72 axles yet.
Sean
ohwell
doing what you love is happiness
loving what you do is freedom
#72130 02/17/2007 7:36 PM
You can buy the '72 axles new, or at least I was able to a couple years ago when I needed to replace one with a grooved bearing surface. There are some differences in axle length and I don't know what years are what length, so you might run into some swap problems there.
#72131 02/18/2007 1:00 AM
Z
Z Offline
1971 up axles are .75" longer than 1970 and earlier.ec sales five lug axles for a 1969.
#72132 02/18/2007 3:04 AM
1 Offline
Thanks, I had a feeling it wouldn't work.
Sean
