| | | Forums66 Topics128,116 Posts1,056,641 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | 59 Chevy 3100 I6 235, 2 wheel drive, Anyone know what transmission came in these trucks. Its a 4 speed. 1St is a granny low. Thanks.
Also it it any good or do you recommend any swaps. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GrandpasTruck, stock four speed would be an SM420, very good , very tough, very popular tranny, hope that helps. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Hy GrandpasTruck, stock four speed would be an SM420, very good , very tough, very popular tranny, hope that helps. And VERY HEAVY! If you remove it from the truck, make sure to have a good jack, or better yet, take it out through the cab with an engine hoist.
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | I use a 4X4 landscape timber 8 feet long through both window openings and a cable come-along to lower the trans to the shop floor, after removing the shift handle. Lots safer than trying to manhandle it. Jerry
